throtle adjusments
Old Jul 20, 2005 | 08:26 AM
barkbarkmeyah's Avatar
Default throtle adjusments
is there any easy way to adjust the throtle on my bike?? the throtle snaps but has a little to much freeplat when the throtle is closed. which cable do i adjust and how, what is the purpose of 2, obviously one pulls the throtle plate open, does the other just help spring back. do i have to take the cables off to adjust the little l thing.
thanks
Old Jul 20, 2005 | 09:43 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: throtle adjusments
On the cables leading to the bar there is an adjustor -- loosen the plastic jam nut and run the adjustor out to take play out of the cable then tighten the jam nut back. It's not really a nut -- it's round but functions as a jam nut. I believe the top cable is the one you need to adjust.
After you get the slack out crank the bike in neutral and turn the bars from lock to lock -- you want the idle to remain constant. If it starts revving higher at any point then you'll need a bit more slack. Most models recommend 2mm of play at the grip.
Old Jul 21, 2005 | 06:59 AM
wow, i cant belive i didnt see that. just so i know, what is the right way to adjust the l thingy.
Old Jul 21, 2005 | 09:18 AM
You screw the barrel piece out to tighten and then run the jam nut up next to it to keep it there.
scastillo13
Aug 11, 2009 03:47 AM
stryker759a
Aug 25, 2008 07:45 PM
sonic0123
Jul 5, 2007 06:39 PM
Enders ride
May 13, 2006 11:28 PM
KISSFAN
Jul 23, 2005 02:45 AM
