tank goes a bit left/right, normal? (dump question)
Old Jul 15, 2009 | 02:27 PM
BlackLion's Avatar
Default tank goes a bit left/right, normal? (dump question)
I removed the petroltank today and when I put on again I didn't get the tank totally tight. (I don't know if it were)
Is it normal when the tank goes a litte to de left and right?
the two bolts are tight and with the rubbers and rings.
(I have got my licence 2 weeks so sorry for the newbie question.)
thank you.
Old Jul 15, 2009 | 03:15 PM
tundrafiend01's Avatar
thank you.
A common occurrence. Your bodywork will help keep the tank in place. You can also buy rubber fuel hose, split it, and fit it between your tank and your frame. I did this on mine and it worked beautifully.
Old Jul 15, 2009 | 03:36 PM
g32bturbo's Avatar
Yea its normal. The rubber fuel hose idea works. Just cut two, 2 inch pieces then slice it down the middle. Slide them on the outer edges of the tank and the tank will rest on those instead of your frame.
Old Jul 16, 2009 | 04:33 AM
Preid's Avatar
I removed my tank to find thick double sided sticky tape. The upfacing side hasnt had the covering layer removed. Works fine.
Old Jul 17, 2009 | 05:44 AM
BlackLion's Avatar
Default tips
thanks for the answers and tips.
where did you guys placed the tape or rubber?
some pics should be nice
Old Jul 17, 2009 | 01:55 PM
g32bturbo's Avatar
move your tank side to side and you should be able to see where it strikes the frame. at that point, put on your rubber.
Old Jul 17, 2009 | 02:57 PM
Sand.Man's Avatar
Originally Posted by g32bturbo
put on your rubber.
Be sure to use the proper technique:
Old Jul 18, 2009 | 05:04 AM
BlackLion's Avatar
It worked thanks, didn't know it was that simple
Old Jul 18, 2009 | 08:13 AM
SJN's Avatar
SJN
Part number for the original rubber is 81214-MW0-300
Attached Thumbnails tank goes a bit left/right, normal? (dump question)-rub-f-tank-side_big17516mj6000-01_24d7.jpg   tank goes a bit left/right, normal? (dump question)-fuel-tank-93-95_bighu0320f1400a_5bbc.jpg
Dennis in NH
Feb 22, 2009 07:03 PM
rep929
Aug 3, 2008 09:48 PM
§T®ÈÈT¿ÃÈMOÑ
Nov 21, 2007 02:35 PM
