stripped bolt
Old 11-05-2009 | 02:36 PM
fusionf5's Avatar
Default stripped bolt
I have stripped the bolt that holds the headers onto the heads. It is made out of aluminum so its very soft. Its kinda to soft. How do i go about re threading this problem. its a 8mm bold. It pretty much has no thread on it since i can pull the bolt right out
Old 11-05-2009 | 02:44 PM
canhead64's Avatar
your gonna have to drill and tap it for a bigger thread, hopefully just a 10 mm will do if you haven't stripped it too bad. much bigger hole that that and you might be screwed.
Old 11-05-2009 | 02:49 PM
Artery's Avatar
If that doesn't work its heli-coil time.
Old 11-05-2009 | 10:24 PM
duececivic's Avatar
ur gonna wanna drill and tap if u helacoil that is a temporary fix and with heat it wont hold long
Old 11-06-2009 | 11:43 AM
fusionf5's Avatar
alright thanks guys
cschew
09-01-2012 02:12 PM
danny600rr
12-14-2006 08:06 PM
uknoejuno51hoe
10-29-2006 09:02 PM
SteeleCBR
10-01-2006 10:09 PM
dizzie56
06-29-2006 07:37 PM
Quick Reply: stripped bolt
