Stripped bolt?
Old Oct 1, 2006 | 02:52 PM
SteeleCBR's Avatar
Default Stripped bolt?
Hey guys,
I'm trying to remove my headlight housing and everything was going very smoothly. However, the very last bolt is giving me trouble. The bolt head itself is not stripped but when I go to loosen it, it just spins and does not come out. I can try to tighten it again but it will just spin forever, neither loosening nor tightening. I think the actual threads in its slot are stripped. What can I do to remove this bolt and will I be able to screw it back in again???
Any help would be greatly appreciated
Thanks
Old Oct 1, 2006 | 10:09 PM
SteeleCBR's Avatar
Default RE: Stripped bolt?
Hey all,
I just went ahead and drilled it out...turns out the metal insert in which the bolt screws into stripped itself away from its plastic cavity so it was just turning inside the cavity with the bolt....not sure how im goin to fix it yet but i will somehow, I was think about crazy gluing the insert back in the cavity.
cschew
Sep 1, 2012 02:12 PM
fusionf5
Nov 6, 2009 11:43 AM
danny600rr
Dec 14, 2006 08:06 PM
uknoejuno51hoe
Oct 29, 2006 09:02 PM
dizzie56
Jun 29, 2006 07:37 PM
