Stator Wires "Question About Location"
Old Jun 11, 2007 | 12:53 PM
Krokus_92F2's Avatar
Default Stator Wires "Question About Location"
Hey Guys, I bought a new Stator for my F2 after replacing the Rectifier and Battery and still always having a dead battery. Anyway, I pulled the old Stator out and disconnected the wires from the plug up by the battery. I did this before opening the new Stator and discovering I had to assemble a new plug and run the wires up through a plastic tube. So..... all the wires are yellow and I didn't pay attention to which wire went to what location in the plug. I figured it didn't matter since they were all yellow. I bought a new battery, charged it up, rode the bike on Saturday and this morning the battery is dead.
My question, is there a specific way the 3 wires from the Stator need to be hooked up in that white little connector attached to the battery box?
Any help would be much appreciated.
Old Jun 11, 2007 | 05:08 PM
amaank's Avatar
Default RE: Stator Wires "Question About Location"
If i'm correct those 3 yellow wires are going to the voltage recitifer. I've been reading a lot of threads about rectifiers and people have said that the 3 wires coming from the stator are indeed interchangeable.
Someone back me up here please. [sm=tongue.gif]
Old Jun 11, 2007 | 06:16 PM
ORIGINAL: amaank
Interchangeable, that is what I thought. I guess the new battery I had bought last month wasn't any good., or...... my POS Dealer said they charged itcorrectly, but I bet they quick charged it.
Old Jun 11, 2007 | 06:20 PM
amaank's Avatar
If you're still having problems, which i kinda assume you are...
This thread helps you diagnose the charging system pretty thoroughly.
http://forums.cbrworld.net/forums/140473/ShowPost.aspx
Maybe you've seen it already... out of curiousity what kind of rectifier are you using?
Old Jun 11, 2007 | 07:08 PM
ORIGINAL: amaank
I am using a Rectifier I bought from Rick's Electrosport or something like that. It has a built in heat sink and I run an extra ground wire. My first problem was a fried Rectifier, so I replaced it and bought a new battery, changed the wiring harness, and even installed a guage that tells you how much voltage is going to the battery. I get 14 volts, but the battery keeps going dead. I will test the electrical one more one time, then the F2 is going off a cliff. Not really I love my F2.
I have an MV Augusta Brutale 910 R, I used the battery from it yesterday but put the Honda battery back in last night. This morning it was dead.
Old Jun 13, 2007 | 04:45 PM
redf12x's Avatar
i replaced the battery and the reg with an OEM one and so far no problems.
bkubes
Sep 13, 2011 11:00 PM
Legacy
Sep 16, 2010 08:00 AM
rbhcbr600
Jul 22, 2010 09:22 PM
BStrand29
Apr 19, 2009 09:42 PM
BlkCBR600
Dec 31, 2004 03:45 AM
