Starter not turning
So the other day my 94 600 wouldn't start it only cranked for a while then eventually it just stopped and would only make a single clicking noise. I replaced the battery and still it only makes a single click when I push the starter
Button. I held the button for a few seconds and the battery blew up
As well. I figured the starter was jammed and taking all the juice it could to try to get it to turn. I can bump
Start no problem. I bought a new starter but I'm not
100% sure what the best way to install it. Could
Anybody give me some insight into if the starter is most likely my problem
And how to properly replace it. Thanks
Try taking the stator cover off the clutch side and make sure everything looks good in there with the starter.
Check the idler gear.
Then watch the starter when you push the starter button.
After I switched the starter and shook the bike a little then I got a grinding noise so I already took the stator cover off and found that the idler gear had
Broke and was digging into the case that's why it wasnt spinning. Found a video online with the same issue going to copy what he does and see what I get.
Cmarchandpr
Jun 19, 2013 05:04 PM
