Small vacuum line from the petcock connects to?
Old Apr 3, 2011 | 10:07 AM
underground-mpyre's Avatar
Default Small vacuum line from the petcock connects to?
Where on the motor does the small vacuum line from the petcock connect to? I know it is important line that cannot be overlooked.
Old Apr 3, 2011 | 11:17 AM
drzed1980's Avatar
left hand side of the block if your sat on the bike, up th etop near the cam cover.
Old Apr 4, 2011 | 10:02 AM
Monkeybutt2000's Avatar
Yup,bike won't start without it. Supplies vacumn to the shuttle valve in petcock.
Old Apr 4, 2011 | 08:07 PM
CBRInfantry's Avatar
??????????????????????????????????????????? mine was never connected and it ran fine. matter of fact i took it off and plugged the little nipple off the tank
Old Apr 4, 2011 | 10:03 PM
adrenalnjunky's Avatar
line doesn't run to the tank it runs to the petcock. If you plugged the smaller opening coming directly off the tank, you plugged a vent or overflow tube.
Old Nov 9, 2019 | 09:37 PM
Garret Connick's Avatar
I hv a 50 cc greely scooter vac lines intake manifold and carb fuel rouying confusing coming from the tank is a petcock vac opetated fuel valve 2 niplled 1 on top one on bottom top i think goes to nipple on top of carb ts to the intake manifold then bottom line goes to nipple on dideof carb with a fuel filter nipple off the engine block gets a air breather filtet now crankase thers a hose going to the frame ?why thers also a nipple on tjat hose from the gearbox i mean so hearbox to engine breather to frame? Or does thay hose connect to the airbox as well?
Elimax
Jul 29, 2013 06:17 AM
robrea19
Jul 20, 2012 08:56 AM
graygeezer
Jun 17, 2011 07:39 AM
CBRnoobie
Oct 14, 2010 06:16 PM
CBRnoobie
Oct 11, 2010 01:20 PM
