Removing top clamp?
Old Apr 8, 2007 | 06:55 AM
bmg velocity's Avatar
Default Removing top clamp?
If my garage had lights...I'd already know.
To take off the top triple on an F2..you simply remove the stem cap and nut...take off the bars...and lift the top triple clamp "plate" off.
Correct?
I am going to put the stock bars on my F2 below the top triple clamp...for two reasons....
1. Comfort...it's actually more uncomfortable for me to hold my wrist at a strange, unadjustable angle, than it is lean
over a bit more on the tank, and making the bars more 90 degree to me. The half a*** approach of making a sport bike,
then at the last second trying to make it sit like a standard makes me ill...and is lame...imo.
2. It looks and is cooler.
I know about watching for clearance...levers...hands...cables etc.
Thanks...
Old Apr 8, 2007 | 07:10 AM
bindelsf2's Avatar
Default RE: Removing top clamp?
thats what it looks like to me.. the only thing i see is that the bars have the detents that go into the top triple to keep them straight and from twisting.. how are you going to keep them from spinning when theres force on them??
http://www.ronayers.com/fiche/200_02...mp;parent=5120
Old Apr 8, 2007 | 07:18 AM
The pinch bolts themselves should hold it in place....
That's all that holds aftermarket clip-ons in place.
The little forged lip that acts as a stop on the stock bars and upper plate...hopefully just safety OVERKILL.
Old Apr 8, 2007 | 07:25 AM
If not...my next bike will be a ZX-6...with the lowest, most "uncomfortable"...bars ever seen.
Old Apr 8, 2007 | 08:54 AM
Hey Bindel...was so wrapped up in my rant I forgot to say thanks for the link to the better service guide.
Appreciate it...
Old Apr 8, 2007 | 12:53 PM
cirsory's Avatar
I just put on some new bars under my triple tree also. Yeah thats all you have to do is take off the clip ons, and the stem bolt and the triple tree will come off.
Old Apr 8, 2007 | 01:45 PM
bindelsf2's Avatar
ORIGINAL: bmg velocity
Appreciate it...
LOL no problem man! i use that website for everything..its supposed to be used for ordering part but i use it as a tech manual!
Old Apr 8, 2007 | 02:37 PM
ORIGINAL: bindelsf2
Appreciate it...
It's better than the Honda ones...least the freebees off the net...
Old Apr 8, 2007 | 02:48 PM
Oh...BTW...
Without cutting down the fairing a bit...there is just no good way to put anything stock handlebar as a clip-on.
You either will pin your hands against the tank...or a lever...or...___________.
That's ok...I saw a guy in here with a post about $2 rear-sets...
This is genius...should be stickied...
https://cbrforum.com/m_155821/tm.htm
DragonCBR
Jan 29, 2010 06:18 PM
LMP1327
Dec 29, 2009 07:39 PM
f4iguy8804
Jun 6, 2007 09:12 PM
97F3
May 21, 2007 09:17 PM
