Rear sproket
Old 06-18-2008, 06:27 AM
amanc96's Avatar
Default Rear sproket
Hi, I just got my tires changed yesterday. I went to put my rear wheel back on and as i was getting ready to torque the axel, i noticed there was some play from side to side with not the sprocket, but the part the sproket bolts onto. After i torqued it down, it wasn't as bad. I was just wondering if this is normal, if not, what do i need to do to fix it.
Old 06-18-2008, 02:33 PM
rider0033's Avatar
Default RE: Rear sproket
if your talking about right under the sprocket....yes thats normal. it's called the cush drive. you know when you put your bike in gear and it jerks forward just a bit. well that is the final drive engaging (final drive=from the tranny countershaft to back wheel). so there are little rubber cushions in between the wheel and the sprocket to keep from destroying your wheel. can any one else say it better i dont know if the way i worded that is understandable
Old 06-18-2008, 02:38 PM
rider0033's Avatar
ok long story short your sprock3t and "th3 part 1t bolts on to" sl1d3 off for acc3ss to th3 cush driv3s. 1s that b3tt3r?
damn 1t wont l3t m3 post aga1n
Old 06-18-2008, 08:20 PM
amanc96's Avatar
Thanks, theservicemanual calls it the Driven Flange. It doesn't seem as bad.
drunkinmist
08-15-2009 08:35 AM
Papi Chingon
03-13-2008 07:10 PM
hondabike
07-24-2007 06:59 PM
italinstalin
09-15-2005 12:48 PM
Quick Reply: Rear sproket
