rear rim
i wanted to get a bigger back tire i have a 160 on now i wanted to know if i can get any other rim thats a 180 and put that on or if they are specially made for the f2s or can i just get a 180 tire and that would fit my current rim?
thanks
thanks
You can stuff a 180 onto your 160 rim, but it will effect your cornering. Or you can put an F3 (wider) rim on your F2, which I believe just takes some different spacers. Not sure, but I know you can search somewhere on google for steps on how to put on an F3 wheel.
You will have to get a 5" rim off of a FV model etc. The early FM model like mine had a 4.5". On 5" riml the only mod I had to do was cut the bearing rubber on the disk side to accept the FM spacer. I use Pirelli supercorsa pro diablos as everyone else that races steelies. I have no hadling issues and mega grip levels, and turning into corners is just as quick because of the 55 profile which gives it slight bigger height.
romanboy
Jan 6, 2013 07:57 PM
berga
F2 Tech
Mar 25, 2010 09:11 PM
