Question About Useing 95-97 Fairing on a 94 CBR 600 F2
Old Apr 20, 2008 | 01:56 PM
Ayres_08's Avatar
Default Question About Useing 95-97 Fairing on a 94 CBR 600 F2
Hola, I just bought a 94 CBR600 F2, The Fairing needs to be replaced and I found a few fairing kits, (see links below) I was wanting to know what problems I would run into if I used the #2 fairing kit on my bike versus the #1 kit. I like the way #2 looks although its for a slightly newer bike. The bike I bought is in Excellent shape mechanically, just needs some prettying up. Thanks
#1 (91-94) : http://i23.ebayimg.com/02/i/000/c9/ae/0d4c_1.JPG
#2 (95-97): http://i167.photobucket.com/albums/u...nda/f898_1.jpg
Old Apr 21, 2008 | 12:02 PM
jahnaboi's Avatar
Default RE: Question About Useing 95-97 Fairing on a 94 CBR 600 F2
Well the only things you'll be running into is the fairing stay for the f2 isn't exactly a bolt on process for the f3 upper. The mounting holes for the upper part of the fairing stay don't line up, and neither does the positioning of the f2's holding point for the headlight. Also, your f2 headlight is different from the f3 headlight which means you would have to switch headlights. If you plan on changing your headlight, and the fairing stay for the "flush stock" look, then I say go ahead and do it. If you don't plan on doing that much, then stick with the first kit and make her look hella clean. =) Up to you though.
-Jasper
Old Apr 21, 2008 | 12:30 PM
Ayres_08's Avatar
Looks like I will just make her look clean, there isnt much difference in them anyways.
Thanks for your input.
Old Apr 21, 2008 | 04:48 PM
tazshido's Avatar
There is one more thing to keep in mind. The radiators sre different from the F2s to the F3s. I have an F2 with F3 bodywork (the headlight and stay are F3) the vent panels on the sides have to have the front holes widened to allow them to clear the F2 radiator.
Old Apr 21, 2008 | 08:56 PM
jahnaboi's Avatar
No problem. Usually people are cut for the price it takes to have a clean looking swap. But at the same time, you could use less money on your current stuff to make a really clean f2 and keep its integrity. =P
-Jasper
Old Apr 22, 2008 | 04:12 PM
tazshido's Avatar
The ONLY reason I went with the F3 body is because the expensive and hard parts had already been done and the majority of the peices that came with the bike were F3. Otherwise I would have stayed with the original body style and probably been happier with the look.
Old Apr 22, 2008 | 05:00 PM
Ayres_08's Avatar
ORIGINAL: tazshido
Well i like both looks, im thinking of getting a primer'd set and then painting it black with right wheels.
Ive seen a few bikes like that and I love the look.
Old Apr 23, 2008 | 12:53 AM
Ayres_08's Avatar
Read my new thread. Thanks
eMChen112
Apr 2, 2013 03:31 PM
loki32687
Aug 21, 2012 05:34 PM
leedutcher
Aug 28, 2008 02:52 PM
rray12288
Jul 3, 2008 06:20 PM
birde
Jan 15, 2008 06:35 PM
