Petcock question
Old Jan 11, 2009 | 06:38 PM
camaropower's Avatar
Default Petcock question
If you have the gas tank off and level in its normal position, if you turn the gas on or to reserve, is some supposed to continuously come out? Like a constant trickle or something?
Old Jan 11, 2009 | 08:36 PM
g32bturbo's Avatar
Default RE: Petcock question
no. our petcocks are vacuum actuated. fuel wont flow unless you have vacuum. if you have a trickle, you have a leak.
Old Jan 11, 2009 | 09:08 PM
Oh ok, thank you for the reply, I'm guessing my 900 has a leak then cause fuel flows out of it with the tank off of the bike and the petcock on
Old Jan 12, 2009 | 12:10 PM
g32bturbo's Avatar
does your petcock have two lines coming out of it or one?
Old Jan 12, 2009 | 04:46 PM
I'm not sure wich one you are talking about, but either way, both have 2 lines
Old Jan 13, 2009 | 04:57 PM
g32bturbo's Avatar
ah, then yes you're running a vacuum actuated petcock. your best bet (to save money) is to take apart the petcocks and see if everything looks ok inside. if you take your tank off and leave the petcock in the on position, fuel isn't supposed to come out.
hindsey123
Apr 13, 2013 08:23 PM
larry1096
Jul 21, 2012 12:23 AM
Dude71
Nov 28, 2011 08:54 PM
BStrand29
Apr 22, 2009 04:21 PM
camaropower
Mar 16, 2009 04:53 PM
