ok guys here is another one plz help
Old May 9, 2013 | 06:37 PM
hindsey123's Avatar
Question ok guys here is another one plz help
so i have a ticking or rattling whatever you want to call it trying to figure out if it is the CCT this is a link to the video
want to figure this out soon so if it is the CCT i can order a manual one thanks guys
Old May 9, 2013 | 07:45 PM
hindsey123's Avatar
also can i ride without hurting anything until i get a manual cct if thats what the noise could be ?
Old May 9, 2013 | 08:10 PM
gotama's Avatar
when was the last time you had your valves checked???
Old May 9, 2013 | 08:44 PM
hindsey123's Avatar
never have just got the bike last year at the very end of riding season how hard are they to adjust can i still ride for now?
Old May 10, 2013 | 09:25 AM
hindsey123's Avatar
ok guys i just need to know if i am going to hurt the bike by riding to work and back untill i get a new manual cct thanks
Old May 10, 2013 | 11:48 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
After the initial inspection, at 600 miles, the next interval, for inspecting the vale clearance, is 16,000 miles - whether or not that it as an easy job or not, is based on your knowledge and mechanical skills, so that's not an easy question to answer... the process is from section 3-5 to 3-9 in the Honda Service manual, check it out and see if you think you've got the chops and tools to get it done.
I will add, that most of the time, if the bike has been well maintained, the valve clearance is still in spec, at the 16K interval.
On the noise, though it's hard to be dead-on, based on the vid, but it sounds like it could be the CCT - if the seems to dissipate somewhat when you rev it, then get loud again when you let off the throttle, then that is most likely the source of the noise - often times the sound is described as nuts and bolts rattling in a steel can.
You could keep riding, but bear in mind, that if this thing does get worse, and the cam chain is allowed to get even looser than it might already be, you could end up with one or more "dropped valves", resulting in all kinds of serious engine damage.
Just to put it out there, the truth is, I personally don't recommend a manual CCT for anyone that is not very mechanically inclined, as it does require periodic adjustment, unlike the OEM hydraulic tensioner.
Bottom line, it's totally your call, as well you know, just be aware of what could happen... I'd hate to see you with a new boat anchor in the form of your F2 motor!!
speeddemonx60
Feb 7, 2010 11:02 AM
3v1lj03
The Hurricane Saloon
May 1, 2009 09:59 AM
gotcbr
Apr 29, 2009 04:23 PM
Apocal
Jul 23, 2007 08:11 AM
acidfire52
Jul 17, 2007 07:27 PM
