oil cooler leak?
Old Nov 26, 2009 | 11:28 AM
JimmyHoffa's Avatar
It's kinda nice. The only problem I have after I go over something myself, is that I become excessively paranoid. Somehow after I see something complex and work on it, my brain suggests about 2,000 possible failure points and resulting catastrophic situations, and plays them back to me while I'm riding my bike. All the time. It gets annoying.
I also feel like something is more "mine" when my wrenches have touched every single fastener on the bike, bar none.
If you need any more help, I gotcha.
Old Nov 27, 2009 | 11:15 AM
mightymouse657's Avatar
Thanx. I know exactly what you mean. Ive done so much to this bike that I started thinking about how many things I couldve messed up. I keep thinking Im gonna ride down the road and its gonna just fall apart into a million pieces. But its great to show people a before and after pic of the bike and hear there reactions. Nobody thought it would ever be a functioning bike when they first saw it, and I just kept telling them to wait and see. Now they all want to buy it, haha.
Old Mar 14, 2021 | 05:06 AM
Phouse's Avatar
Default Cooler
Originally Posted by mightymouse657
So I have been tirelessly working on my f2 for the past 4 months to get it finished (basically replacing everything minus engine and frame) and im all done but found one problem. I changed the oil and filter and when I fired it up the let it warm up I noticed a drop of oil forming on the bolt right below the oil filter that holds the oil cooler on. So I assume that its the o-rings in the cooler that have gone bad. I replaced the 2 that go on the collars that are inside the block but forgot about the other two on the collar. Could this be the cause of the oil leak. Ive also noticed that the coolant is mixing in the oil, which is another reason I thought it was the o-rings. Im praying its not a head gasket. Any advise or help?
I just have a little question for you.. Can I remove the oil cooler unit without remove the pipes... Thanks.
Old Mar 14, 2021 | 11:01 PM
According to the manual, removing the exhaust is not required.
Old Mar 15, 2021 | 03:22 AM
Phouse's Avatar
Default Weepy coolant
Thank you so much for your reply... It sounds like I'm good to go.. I've been studying it for a day or two... And saying to myself that"ll come out of there... Sometimes taking the pipes off older bikes can be a nightmare as I'm sure you know... So thanks for the confirmation... Most helpful...
Thanks.
Old Mar 15, 2021 | 08:17 AM
Do a Google search for the PDF of the shop manual. It will walk you through the process.
Old Jun 21, 2023 | 12:16 PM
shawn101's Avatar
Default Oil cooler parts
I think that you're right on the money with the "O" rings going bad. Remember they're 17 or so years old. Left undisturbed, they would have probably lasted a while longer. If you took the oil cooler apart, anyplace that there was an "O" ring, it should have been replaced. As for the coolant and oil mixing, yes, it's highly possible that "O" rings are the cause. Because coolant is used to cool the oil in a heat exchanger type of process, it's easy for the two to mix. Are you finding oil in your coolant, or coolant in your oil ?. I would suggest replacing all of the "O" rings.
where do I find the parts to fix my oil cooler having the same problem and can’t find parts for it
Old Jun 21, 2023 | 01:16 PM
rockpool's Avatar
What part are you trying to find?
https://www.hondapartsnation.com/oem.../crankcase-set
rapidspec
Jun 8, 2011 05:50 AM
jbrogan2007
Mar 26, 2011 04:48 AM
sumsk8erbum
May 20, 2009 11:43 AM
CBRwarrior
Mar 31, 2008 09:06 PM
