not running right
Old Aug 26, 2009 | 08:26 AM
motogpman's Avatar
Default not running right
hi last night i was on my way home from work when my bike started making some funny noises. it sounds really wierd like its not when you touch throttle from idle it stutters a bit and doent want to rev freeley. i checked the oil to make sure it haddropped down a little bit but still above the minimum mark i topped it up just to be sure and noise is still there can any one suggest anything
thanks you very much
jamie
Old Aug 26, 2009 | 11:53 AM
Bently600's Avatar
Can you describe the problem in more detail... when does it occur (at idle/under load/in 1st/from a stop....etc.)? what kind of sound is it? what kind of power loss do you feel?
Old Aug 26, 2009 | 12:30 PM
usmcrider's Avatar
You're gonna have to describe it a little better like the guy above said.
Old Aug 28, 2009 | 07:20 AM
motogpman's Avatar
hi
its not firing on 3rd cylinder i have checked that its getting fuel and i am just about to get another ht lead to test on it.
Old Aug 28, 2009 | 03:24 PM
johnnyx's Avatar
Is the plug sparking? What does the plug look like? Is it wet?
Old Aug 28, 2009 | 07:10 PM
motogpman's Avatar
plug is not sparking but is getting fuel i put a new plug in and have tried swapping the plugs about to different cylinder. next i tried new ht leads today to see if that helped but after starting on all four cylinders droped back down to 3 after about a minute should have a different coil to try tomorrow but other that that i cant think what it might be.
thx for the replys.
gundamknight07
Jul 26, 2012 08:24 AM
rolli
May 27, 2012 09:25 AM
entity-unknown
Mar 20, 2009 11:55 AM
motoman358
Jul 2, 2008 08:59 PM
Kym
Jun 22, 2008 07:33 PM
