Newb Chain Question
Old Nov 13, 2008 | 10:12 AM
jagdiver's Avatar
Default Newb Chain Question
Alright, brand New to bikes just picked up a 93 f2 that was laid down but the damage is mostly cosmetic except for a foot peg and a bent shifter. However the chain looked loose to me he said it had fallen off and he had not adjusted since the lay down. Is there a good write up on how to tension the chain and what kind of slack its supposed to have? I am unsure of the specs here. I know there are the marks to follow and all that just not sure how tight to get it. (supposedly the chain and sprocket are almost new however the chain looks pretty old)
Any help to this newb would be appreciated
Old Nov 13, 2008 | 10:34 AM
amRRussel's Avatar
Default RE: Newb Chain Question
On mine I make it to when I am sitting on the bike there is between 1/2inch to 1/4inch slack. Not sure how acurate this is, this is they way I have always done it from dirt bikes, quads to street bikes. works for me.
I am sure someone on here will be able to have the correct specs
welcome to the community
Old Nov 13, 2008 | 10:05 PM
jagdiver's Avatar
Alright, thanks for the reply it gives me a place to start.
Thanks
Old Nov 14, 2008 | 04:07 AM
eweppley's Avatar
My Clymermanual says that chain slack should be between15-25mm(5/8" - 1"). Hope this helps.
Old Nov 14, 2008 | 08:46 AM
Hurricane rider's Avatar
the previous owner said the chain FELL OFF? you need to replace the chain and sprockets. when the chain falls the eff OFF, it usually causes damage to something or another else quite important, such as perhaps your sprockets.
adjusting the slack is easy. just loosen the axle, then using a 12mm open end wrench, loosen the locknuts on each adjuster, they're on those bolts sticking out of the end of your swingarm. adjust both sides equally, of you're GOING TO HAVE PROBLEMS.
Old Nov 14, 2008 | 10:43 PM
jagdiver's Avatar
the chain had come off when it was laid down after hitting a deer, but after going over the bike the majority of the damage was cosmetic (plastics) and the left rearset will need to be replaced but is functional.
Old Nov 14, 2008 | 11:38 PM
doesnt matter, if the chain came off, that to me is an obvious sign of HORRIBLE maintenance, meaning the chain is likely screwed by this point. I dont trust any chain that has come off for ANY reason other than a human removing it. cant and dont trust that crap. ever.
Old Nov 15, 2008 | 10:40 AM
jagdiver's Avatar
Alright, thanks for the info I will be sure to look into it
Old Nov 15, 2008 | 02:33 PM
Hoosier1104's Avatar
New sprockets and chain is the best way to go in this case. http://www.indysuperbikes.com is where is got my quick acceleration kit. Vortex sprockets and a 520 X-ring chain.
shinna202
May 4, 2009 06:47 PM
oodayvidoo
Dec 12, 2007 10:06 PM
mean91eagle
May 20, 2007 02:00 PM
Donohu40
May 7, 2007 02:13 PM
Daemian
Apr 24, 2007 06:45 PM
