New Sprocket
Old Aug 30, 2007 | 12:11 AM
Brewtus's Avatar
Default New Sprocket
I need to get a new sprocket and I am not sure how many teeth would be best. Any recomendations? The one that is on there is completely worn. The teeth are sharp points right now.
Old Aug 30, 2007 | 01:15 AM
Tripwire25's Avatar
Default RE: New Sprocket
Is it a front? rear? Do you want to stay with stock gearing? Is it just normal wear? Or is something causing it prematurely. If its time for a new sprocket, you might consider replacing both front and rear and a new chain.
Old Aug 30, 2007 | 06:54 AM
MikeInCtown's Avatar
If the sprocket is that bad, the front is probably just as bad and the chain will also need to be replaced. Stock is 15F and 43R.
Old Aug 30, 2007 | 10:48 AM
drgonzogoo's Avatar
a couple months ago i needed a new chain so i got a 520 conversion kit. it came with an rk gold chain and vortex sprockets, the rear was stock and the front was -1. its not much but with the lighter chain and lower gearing i can notice a difference in acceleration but i'm not screaming down the highway at high rpm's either. hope this helps your search
Old Aug 30, 2007 | 04:43 PM
Brewtus's Avatar
So less teeth =acceleration and more teeth = top end? More or less
Old Aug 30, 2007 | 05:11 PM
kawyman's Avatar
Brewtusgo with a 14 front 45 back makes the bike pull nicely 1st,2nd,3rd gears and its funny to have the low end torque for wheelies
Myfirstcbr
Mar 22, 2013 09:40 AM
DunnRR
Jun 10, 2010 02:31 PM
