Motor mount questions
So i got all the bolts in the right places. I am just unsure of the spacers. I need to know which spacers go near the radiator. ANd also which ones goe where the the triangle mounts are. I think the ones on the triangle mounts are symmetrical? and the Rad. mounts are not. But i would really like to make sure, and i can't tell from the small pic in the manual. Any help is greatly appreciated.
The left side triangular hangar mount is shorter than the right side. The left side is about 1cm long, and the other side is slightly longer.
On the front toward the radiator, the absurdly thin one goes in the right side. The spacer on the front left side is just over 2cm long.
There is only one spacer that comes even close to working in the rear upper hanger pinch screw assembly, and if I recall it's quite long. I assume you got that much.
heavychevy
Jan 12, 2007 11:22 PM
