what is the biggest motor you can mount on a f2 frame
Old Mar 1, 2006 | 03:45 PM
heavychevy's Avatar
Default what is the biggest motor you can mount on a f2 frame
what size motor can you put on f2 frame
Old Mar 14, 2006 | 04:41 AM
DThompson's Avatar
Default RE: what is the biggest motor you can mount on a f2 frame
I dont think there are to many people that have been swapping engines. Id just take some measurments of the engine cage area in comparison to other bikes. It would probably cost a lot of money to convert this also. Probably better off buying a bigger bike.
Daniel Thompson
Old Mar 14, 2006 | 12:57 PM
richterat83's Avatar
Are you good at fabrication? If not, the size of your wallet will decide the size of the engine.
Tylor
Old Mar 14, 2006 | 01:25 PM
kulrevon's Avatar
I believe a cbr 900 bolts in pretty simple with small modifications.
Old Mar 16, 2006 | 03:05 PM
chaos321's Avatar
The 900rr motor will fit, with some mods to the motor mounts and also the top brace that runs from left to right above your airbox has to come out. Now if you think about it, the new 919 has the same 900rr motor,and it has fuel injection. Oh the possibilities!
Old Mar 17, 2006 | 11:59 AM
kulrevon's Avatar
Do you know anywhere I can find info on the 900rr swap into the 600?
Old Mar 17, 2006 | 01:06 PM
chaos321's Avatar
There used to be a site called motomorph but they went out of business. It ends up being trial and error. You might try google and see if there are any other CBR sites or F2/F3 sites.
Old Mar 19, 2006 | 07:51 PM
rangerracer's Avatar
can you fit a motor from a newer 600?f3/f4/f4i?
Old Mar 19, 2006 | 08:35 PM
13brsxsrr's Avatar
ORIGINAL: heavychevy
I might be wrong but i don't think Honda intended for 900rr engine to fit a f2 chasis that old. The frame, forks, and swingarm are different. Not saying that it won't work but why not just put an f2/f3?
Old Apr 20, 2006 | 03:15 PM
turboinferno83's Avatar
Why do most of the people here have nothing but bad stuff to say about anything that seems to be different in the way of what was factory design.Maybe this is a hobby or just a fun little project for someone.Don't come around spitting your useless thoughts at everyone.We don't want to here it.Today people we want to know what engine is known to fit in this chassis.I read of this on a forum at cbrworld.net.There was some modification.The modification can be done yourself using a cutting/grinding wheel,and a welder.pick these up your self can save big bucks.
the top of the frame was notched is one thing i remember and the head looked tight in the top area of the frame
