ignition wiring... for a alarm
yeah i thought i had it hooked up right but no go....i arm it and after 30 sec it goes off for no reason.. and when i use the remote start the high beam light comes on..... i really jacked this thing up.LOL.. its off the bike now. .i think i am going to take the alarm diagram and the alarm wiring diagram to a shop and ask them where they would hook it up too.. i am lost..
okay okay so i have it all wired up!!!! i was scared as hell when i hit the remote start and it started up(the bikes still in the house) and its 2am...![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
but for those that want to buy this alarm...heres the write up!
red wire--straight to red on batt.
black--straight to battery
black with loop--to frame
yellow- one to each side turn signal.
left signalis-- orange/white wire
right signal is-- baby blue wire
pink wire-- to the blue/orange wire from ignition switch( third conn over from shifter side under fairing stay
orange wire-- to the red/black wire from ignition switch(third conn over from shifter side under fairing stay
grey to green/red (peel back the boot from the starter relay and splice in there
blue to yellow/red (peel back the boot from the starter relay and splice in there
you now have a alarm and elec start!!!
I have a different alarm but it has similar features. It has:
-a Brown wire for the ACC
-a Pink wire for the kickstand (the kickstand has a green wire and a green/white wire. Not sure which one to hook up to)
-and Gray for the "ignition module"???
The Pink and Gray work together for the ignition disable feature. I'm lost astowhere to find the correct wires.
I know that my bike is different, but maybe the wiring is similar, and I need all the helpI can get. Any suggestions?
