I need stock exhaust?
Old Mar 6, 2007 | 02:51 AM
ThisisMickey's Avatar
Default I need stock exhaust?
Hey guys so i am hoping a stock exhaust could help reduce backfiring when I drop down a gear. And help it run smoother (my RPM's jump around a little in idle) I bought a stock can off ebay but found that the previous owner cut my header to fit the yoshi on there. So I need a new header too. Annnyyywayy do you guys think that replacing the small little yoshi I have would help with this?
Old Mar 6, 2007 | 02:59 AM
ep03TN's Avatar
Default RE: I need stock exhaust?
An exhaust that is a little too open can cause it to jump rpm's at idle if you bike is untuned. A good test for that is to let it warm up a little and with a glove on cover up half of the exhaust opening with your palm, allowing only half the exhaust from the muffler to get out. If the bike starts idoling normally you have a lack of backpressure problem. The other guys could probably be more helpful with your other questions.
bindelsf2's Avatar
i had a yoshi on my bike and that didnt happen. i think it needs a tuning.
Old Mar 7, 2007 | 01:50 AM
That sounds like a good idea i will try that out ep03TN thank you. And about the tuning, what does that involve is it something I have to take to the shop for, because I really want to do as much on my own as I can. Thanks again
Old Mar 7, 2007 | 02:17 AM
two240s's Avatar
if you end up needing a stock exhaust I have a set of headers and two stock cans.
email me at two240s@hotmail.com if you want it......
Old Mar 7, 2007 | 07:59 PM
ep03TN's Avatar
Well, as far as tuning goes, if your idol jets are or are not putting enough fuel out to make the engine run right then thats your problem. In my case, with my aftermarket jets, they were putting out to much fuel at idol making it run like crap, so we used the stock ones there, and used the rest of the jet kit and it worked great. You probably need to be tuned honestly. What happened when you tried what I said? Exhausts can make a big difference with how the bike runs, and youdefinatly have to tune for the setup your running.
Old Mar 8, 2007 | 04:05 AM
Well unfortunatley I did not notice a difference when I covered some of the exhaust. So do you guys think I should rejett? and if so how do i know what size i want. I think I have 130 main right now
mosso23
Aug 31, 2009 08:48 AM
Uniqsol
May 18, 2009 12:25 AM
whiteflash
Feb 4, 2009 07:49 PM
stunter411
Mar 22, 2008 04:26 PM
