I need some help
Old May 24, 2007 | 07:20 AM
j_bezzy85's Avatar
Default I need some help
[8D] I have a 1994 f2 and I can't get it 2 turn over. It ran good awhile then it was shaking while I was riding so I took it home and it wouldn't turn over but the light and horn were still work. When I did try 2 turn it on it made a clickon sound like it wanted 2 turn on but it wouldn't. Now it doesn't do anything. I changed all my fuses even the 30 amp and I have a brand new battery. Any suggestions out there?????
Old May 24, 2007 | 07:28 AM
bindelsf2's Avatar
Default RE: I need some help
Regulator Rectifier..very very common...mine just went out on friday..
Old May 24, 2007 | 07:32 AM
bindelsf2's Avatar
try this.. great write up! http://forums.cbrworld.net/forums/140473/ShowPost.aspx
Old May 24, 2007 | 09:37 AM
richterat83's Avatar
I would also say it is the regulator/rectifier. Mine went 3 months ago, and, i went out and bought a reg/rec. off of an 06 gsxr. Cut and spliced the wires together and havn't had a problem yet. I will keep everyone posted if I do run into trouble though.
Tylor
Old May 24, 2007 | 07:04 PM
bindelsf2's Avatar
if you need one.. i just got mine in today and it wasnt my reg. it was my ground wire on the starter...[&:]
i will sell it to you for what i paid and no shipping.. its the good one with the cooling fins and everything.. you can see that i just bought it 4 days ago. and i will sell it for 95.00 shipped to youand ship it out the next day....
http://cgi.ebay.com/ebaymotors/ws/eB...043&rd=1,1
Old May 24, 2007 | 08:20 PM
sloppyjones's Avatar
i don't know much about the reg but if you are shaking a little check your spark plug wires maybe it is just firing funny and locking up. how did it idle?
hope that helps
Old May 25, 2007 | 12:01 PM
j_bezzy85's Avatar
The idle was ok when it was running. It jus started shaking & jerking a lil bit when I was riding so that's why I took it home when it started acting up. But I'm going 2 check the plugs 2day and try a running start and if that doesn't work then I'm going 2 try the reg/rec.
