High speed sluggish
Old Aug 1, 2014 | 03:50 PM
Gary Evans's Avatar
Default High speed sluggish
Not sure how to explain the problem im having with my f2 but here goes! when riding at high speed " on a track " im only able to just about touch 120mph when its going at this speed it seems to be lacking go go juice! if i shut the throttle off and re open there is a mega delay, also sometimes it seems when the throttle is open that nothing is coming out. Now this only happens when i am reaching over 100mph, the other problem is when i ride her hard she always idles around 2k with a very racey needle if i try and adjust the idle screw she just dies.. i have checked plugs and they seem ok i have recently bought a new set of carbs hoping it is that, am i missing anything else?
Old Aug 1, 2014 | 03:57 PM
Mattson's Avatar
Seems carb related, though I doubt a replacement would be necessary. Have you recently cleaned your carbs? A proper scrub could do the trick, crap in the jets maybe? One thing can be that the petcock isn't opening properly thus letting through just a little gas so when gunning you're starving the carbs. Do you have a fuel filter? Can be clogged .
Old Aug 1, 2014 | 04:37 PM
Gary Evans's Avatar
i did take my carbs off and gave them a good going over took jets out all clear, i was going to get them syncd but someone had chewwed the syncd screws up so there was no chance of adjusting them, the only fuel filter is the one in the tank and thats clear of anything. Does the petcock oftern have issues on the f2?
Old Aug 1, 2014 | 04:39 PM
Mattson's Avatar
Not often but they are known to fail, the vacuum membrane can rupture however it usually fails to open completely then but I guess anything`s possible...
g32bturbo
Feb 4, 2009 07:35 PM
Coopz
Nov 15, 2007 03:55 AM
jchavers_2000
Apr 10, 2007 04:24 PM
dizzie56
Aug 12, 2006 01:38 PM
04CBR600
Jun 21, 2005 10:16 AM
