High speed sluggish
Not sure how to explain the problem im having with my f2 but here goes! when riding at high speed " on a track ;) " im only able to just about touch 120mph when its going at this speed it seems to be lacking go go juice! if i shut the throttle off and re open there is a mega delay, also sometimes it seems when the throttle is open that nothing is coming out. Now this only happens when i am reaching over 100mph, the other problem is when i ride her hard she always idles around 2k with a very racey needle if i try and adjust the idle screw she just dies.. i have checked plugs and they seem ok i have recently bought a new set of carbs hoping it is that, am i missing anything else?
Seems carb related, though I doubt a replacement would be necessary. Have you recently cleaned your carbs? A proper scrub could do the trick, crap in the jets maybe? One thing can be that the petcock isn't opening properly thus letting through just a little gas so when gunning you're starving the carbs. Do you have a fuel filter? Can be clogged .
Originally Posted by Mattson
(Post 1278487)
Not often but they are known to fail, the vacuum membrane can rupture however it usually fails to open completely then but I guess anything`s possible...
