shakin at high speed
RE: shakin at high speed
Does not sound good to me! You do not mention what bike you ride, but any modern super bike should be able to run 120mph with one hand on the bars. Start by checking tire pressure and also look for bad spots on the tyres. (uneven wear) Further have your suspension checked out, maybe there is a problem with the setup or even a shock that is faulty
Seeing that it is a 05 CBR 1000RR, it sounds even more suspicious as the HESD should be able to sort out any shaking. Also have this checked out, but start with the more obvious like tyre and suspension setup as this is more than likely what the problem is.
I will also be posting some suggestions on suspension setup for track use and you can use this as reference to give your suspension a run over.
thanks guys. ill definetely check the tire pressure out and if that aint it im bringin it right back to the dealer and tellin him to fix it. scared the crap outa me goin that fast and then shakin. its smooth as hell up till i hit 120 then its shakin like a bitch. only had the thing for bout a month now so it better not be movin like this
Wow, I would say that's not normal; mine seems to get more stable the faster it goes...head to the shop and let them check it out....bad joke but I can't resist, are you sure its the bike and not you that are shaking? Just kidding, but the 1krr is serious thrill ride, guaranteed to get your blood pumping
