help!! speedo trouble!!
Old Apr 24, 2006 | 11:03 PM
92CBR's Avatar
Default help!! speedo trouble!!
i was ridin today and stopped for gas....when i started up again my speedometer wasnt workin and my mileage and trip counter werent rollin. The tach which is right beside is workin fine as well as the temp gauge....just the speedo is dead. any help would be appreciated....
BTW its a 1992 Honda CBR 600 F2
thanks!!
Pete
Old Apr 25, 2006 | 01:04 AM
92CBR's Avatar
Default RE: help!! speedo trouble!!
ok i figured it out!! thanks anyways!
Pete
Old Dec 9, 2006 | 02:08 PM
elmer's Avatar
I'm having the same problem, what was your solution?
Old Dec 10, 2006 | 04:08 AM
zerochickenstrips's Avatar
I'm guessing the speedo cable either came loose from the gear box at the front wheel or from behind the speedo (screw on connection) or the inner cable broke. The speedo is mechanically operated while the tach is electronic. That's why one works while the other doesn't.
Old Dec 10, 2006 | 09:50 PM
LaynLo17's Avatar
how do you recalibrate the speedo? mines off by a good 15mph and the tire size in freont is stock.
Old Dec 11, 2006 | 11:24 PM
elmer's Avatar
so in all likelihood its either the drive gear or the cable, correct? I'm really hoping that the speedo itself isn't damaged.
Eric Peil
Apr 29, 2019 09:44 AM
WildWill
Mar 21, 2009 10:10 AM
exz5string
May 13, 2008 10:18 AM
slimmyslim1420
Mar 23, 2008 08:24 PM
