hard warm start???
Old May 16, 2009 | 10:44 PM
tcougle's Avatar
Default hard warm start???
Hoping someone can give me an idea of where to start.... My bike runs great all the time and starts cold with no problem, but if i'm out on the bike and shut it off for more then five mins and try to restart it within an hour so it wont start right away i have to pretty much flood the it then it will start typically take bout a minute of cranking or so any ideas?? please help thanks tim
Old May 17, 2009 | 06:22 AM
CaliKush's Avatar
i might be way off but imma say clogged carbs, or clogging carbs.
Old May 17, 2009 | 07:32 AM
Phil314's Avatar
You're idle mixture screws on the carbs are set too rich. I had the same issue, starts great cold, hard to start when hot. Pull the carbs, remove idle screws, clean passages good, install screws, set them 1/4 to 1/2 turn more in and see it that helps.
Old May 17, 2009 | 06:11 PM
tcougle's Avatar
thanks guys will try that this week and let you know how it turns out
Old May 17, 2009 | 07:37 PM
cowboy from hell's Avatar
if yours is a CA model check the pcv
Old May 18, 2009 | 08:41 PM
tcougle's Avatar
how would i know if it a cali model
Old May 19, 2009 | 06:40 AM
easiest way is to look under ur swingarm in front of your rear tyre if you see the charcoal canister then u got got a cali
Old May 25, 2009 | 08:37 PM
tcougle's Avatar
where do i find these idle mixture screws?
Tikkaman
Apr 21, 2012 02:42 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
str8krewzn
Mar 25, 2010 03:33 PM
JayBoCC2
Jun 23, 2009 10:23 PM
revditup
Oct 17, 2005 03:02 PM
