hanging idle
The bike developed a hanging idle since I last rode it. It's been down a month since I have replaced the entire braking system etc, but it has been started twice during the month period though.
When I let off the throttle to shift to the next gear, the rpm is maintained for about an additional 2 seconds before it falls as normal, thus the hanging idle.
I'm guessing it is a carb issue, just dont know what is clogged. I have never taken a carb apart before, just curious to see if anybody else has ever had this issue.
I went ahead and did the lazy thing of pouring a fuel injector/carb cleaner into my gas tank. I am going to run it through, maybe it will help, maybe not.
it def sounds like your throttle cables are sticking. You should try some cable lube for them to see if it gets easier. Mine sticks too and it is the cables. Also like stated before, check the throttle tube. it could be catching on the bar causing it to rotate back slowly. It doesnt sound like a carb problem thought.
