front turn signal
Old Jun 13, 2015 | 04:25 PM
gpfan1's Avatar
Default front turn signal
This kind of embarrasing, but here goes. I have a 91 f2 since new. For the first time I have to replace the front turn signal bulb. The manual says "remove the under screw and pull the fixture out." I have tried without success to remove that little bugger. I looked up parts and know there is a hook tab on the front of the lens. I have tried pushing in on the front while pulling at the back and every permutation available. I stop, because it is only plastic and I really don't want to break it. I modified my body work tabs to make it easier to remove and replace as it always felt like I could break them at any time. I'm guessing that the light lens is no different.
So, anyone got any tips on pulling the lens?
Thanx
Old Jun 13, 2015 | 07:44 PM
Phil314's Avatar
Thanx
Last time I pulled mine (a while ago) I seem to remember that you just remove the under screw. Then you kind of twist the lens out of the bodywork. You don't pull it straight out, it kind of pivots a bit and then comes loose.
pmcg
CBR1000F Wanted / Swap
Aug 14, 2012 12:23 PM
Pinoyisme
Oct 6, 2010 07:56 PM
ssjnimma
May 29, 2008 07:26 AM
