front master cylinder
Old Dec 27, 2009 | 08:40 PM
halffast1g's Avatar
Default front master cylinder
One of the screws for the cap on the master cylinder is stripped out. I tried drilling part of the screw and use an ez out but no dice. Anybody got a good front master cylinder for sale without stripped screws or some advice?
I am trying to bleed the brakes so I need to add fluid to the reservoir
Old Dec 28, 2009 | 01:40 AM
Fearless4x4's Avatar
Official Welcome Crew Redneck
best bet since you have already tried to drill it out may be to try and get a slot cut into the head and try to get it out with a flat head screwdriver. then (if i remember right you live in tempe correct?) head down to bobs cycles and see if you can get a replacement screw off a wrecked one.
if memory serves correctly, i dont think a dremel makes a bit small enough to cut into that screw whe way thats needed. if you want, my dad has an air powered engraving tool that i can bring by, just need to have an air compressor with a 3/8" quick-connect and a regulator. if you dont i can load mine in the truck.
i live in goodyear. pm me if you would like me to give it a go with that engraver.
Old Dec 28, 2009 | 10:57 AM
halffast1g's Avatar
I may just run over to bobs to buy a new master cylinder. I'm so sick of all of the seized/stripped out bolts the last owner left me. I guess it should be expected on a bike almost 20 years old.
If I don't have any luck finding one I will try to notch it. thanks for the idea
Old Dec 28, 2009 | 12:22 PM
mullenc525's Avatar
I should have one if you need it. I'll be parting a bike in the next week or so.
curtis.mullen@hotmail.com
Old Dec 28, 2009 | 05:02 PM
LMP1327's Avatar
do you have a wanted ad? if so i pmd you
Old Dec 28, 2009 | 09:31 PM
halffast1g's Avatar
pm'd back
Old Dec 28, 2009 | 10:33 PM
just curious... why would you replace the whole MC when all that is problematic is the screw... just seems like a waste of money/effort. just wondering if there is another underlying problem or not?
Old Dec 29, 2009 | 11:58 PM
halffast1g's Avatar
i bought one from lmp.
I destroyed what was left of it trying to drill/ pry up on the stripped screw to get it out.
paultttt74
Feb 27, 2014 06:05 AM
