Frame sliders
Old Apr 13, 2007 | 02:54 PM
airick's Avatar
Default Frame sliders
Hey guys,
I was wondering if anyone has installed frame sliders on their bike and if there are any pro's/cons in putting frame sliders on your bike. Anyone know where to get a good set for an f2?
Old Apr 13, 2007 | 02:56 PM
bindelsf2's Avatar
Default RE: Frame sliders
do a searchi have posted the write up about 5 times.. i will try and find one and post it..
Old Apr 13, 2007 | 03:00 PM
airick's Avatar
Found em Thanks alot, great write up
Old Apr 13, 2007 | 03:02 PM
bindelsf2's Avatar
cool, heres two methods...
Follow one of these techniques and they will be near perfect:
Here are a few nice installation recommendations from another site:
"You'll need some play doh
1. Take off the fairings
2. Take out the right side engine bolt, I believe this is the side with the pinch bolt, I'm too lazy to go look to confirm but don't forget to loosen it first or you'll be battling with it all day.
3. Install the longer bolt from the frame slider.
4. Now look at the fairing and you'll notice an impression in the foam made from the OEM engine bolt. Cut away enough foam for the slider to go through.
5. Place a hunk of play doh over the spot and remount the fairing pressing the bolt into the play doh. BE CAREFUL TO GET IT RIGHT HERE AS THIS PART IS CRUCIAL to centering up your hole.
6. Carefully pull the fairing off while doing your best to not mess up the impression.
7. Drill a small pilot hole through the centre of the play doh impression from inside out.
8. Tape up the painted side of your fairing with masking tape to avoid chipping up the edges.
9. Use a hole bit/saw (usually 2") and drill the hole through your fairing.
10. Install slider, remove tape and reinstall the fairing.
11. Do the same for the other side.
Alternate method if you have at least a rear stand and a laser level.
1. Mount the bike on the stand, that way she's nice and stable and upright.
2. With the fairings off, line up the dead centre of the engine bolt with the laser level.
3. For OBVIOUS REASONS, make sure the laser level is far enough away from your work area to ensure it can't be knocked, moved etc.
4. Mount the fair back on and the laser level should mark the dead centre on the fairing itself.
5. Mark the hole and go from step 7 mentioned above. "
Zachbw55
May 21, 2013 02:42 PM
captain crash
May 17, 2010 06:30 PM
mdfirefighter
Jan 30, 2007 01:21 PM
hotwire
Apr 25, 2006 01:20 PM
