found the over-fueling culprit!
Old Dec 9, 2008 | 10:31 PM
moto_addict's Avatar
Default found the over-fueling culprit!
got the carbs torn down tonight, and found that the float valve on the #3 carb, the same one that had been dumping fuel, had a faulty spring or it's seized or something. at any rate, the rubber cone end of the valve was fine, so the valve was sort of working, but the spring-loaded pin at the other end of the valve was jammed and letting the valve trickle extra fuel through. i think i'm just gonna get a rebuild kit so i can do all 4 carbs at once. i'll let you guys know how it turns out when i get it put back together
-T
Old Dec 9, 2008 | 10:57 PM
Default RE: found the over-fueling culprit!
yeah ok so i'm cheaper than i thought. anyone near kansas city, MOwith an extra set of F2 carbs? hey i thought it was worth a shot.
-T
Old Dec 12, 2008 | 12:27 PM
baja74vw's Avatar
I would make sure to check ebay. It is really hit and miss, but I picked up a very good condition set of carbs for $9 + shipping once.
Just a thought.
Tim
Old Dec 13, 2008 | 12:31 PM
alright. so....i got a used float valve shipped to me, and it looked NOTHING like the one I'd pulled from the carbs. it was taller, had a steel seat instead of a rubber seat, etc etc. soi decided to...."recondition" the stuck one. after soaking in carb cleaner and penetrating oil and a few helpful taps and gentle yanks with tweezers, the spring-loaded pin freed up and now moves nice and smoothly again.
she goes back together tomorrow, here's to hoping the valve doesnt freeze up again.
-T
NJKneeSlider
Apr 8, 2014 12:49 PM
Garantis28
Oct 10, 2011 10:06 PM
way2s1ck
Jul 11, 2009 05:34 PM
KungFu954
Apr 20, 2009 05:32 PM
cbr_newbie
Jan 8, 2007 03:26 AM
