Flywheel Removal
Old Nov 25, 2006 | 06:19 PM
Zangetsu's Avatar
Default Flywheel Removal
Any tips on removing the flywheel (that's what Bike Bandit calls it: http://www.bikebandit.com/partsbandi..._id~187997.asp ) ?
It's the part that goes around the stator.
#3 in that picture
The "new" engine I bought from the salvage yard was totally stripped, so I have to move all my old parts over. I've got everything else swapped over and the engine in the bike, I just need to get this last big piece done and I can ride!
Thanks!
-Fran
Old Nov 26, 2006 | 02:02 AM
LaynLo17's Avatar
Default RE: Flywheel Removal
i havent had mine off and actually looked but you might need some type of puller for it. if you remove the center bolt you might be able to work it loose carefully. if not then you need a puller. as for what kind i dont know ive never worked on bike engines before. just cars.
Old Nov 26, 2006 | 09:45 PM
Zangetsu's Avatar
Yeah, I need one of these tools
http://www.bikebandit.com/partsbandi...ion_path~2.asp
I tried my gear puller, but that didn't work out at all.
Of course, I had to try this on a Sunday when no bike places are opened so I'm headed to a shop tomorrow to buy the right tool.
I'm in the same boat as you - I've torn apart a number of V8's, but this is my first foray into tinkering with a bike.
Old Nov 27, 2006 | 12:43 PM
Way Fast CBR's Avatar
if you can find a bolt that fits the threds inside the center of the flywheel, that would work. just keep twisting the bolt untill the flywheel pops off. the tool you need is i tnink 60 dollars. i just tryed to find my manual to tell you the part number for the tool. but i think you would be better of trying to find the bolt as it would be way cheaper.
Old Nov 27, 2006 | 01:17 PM
Zangetsu's Avatar
That's a great idea!
Thanks for that!
That's a pretty big bolt tho'... too bad I can't drag the engine into the hardware store with me... (or can't I? LOL)
Any ideas on how big/what thread that hole is?
Thanks again!
JankCibberf2
F2 Tech
Jul 18, 2012 12:00 AM
antireebok
Apr 13, 2012 03:41 PM
pittmeister
Jun 14, 2011 11:06 AM
cbrtripleblack
Nov 30, 2009 11:13 PM
Syphen
Oct 9, 2009 10:23 PM
