Flat spot
Old May 19, 2007 | 03:51 PM
Foght's Avatar
Default Flat spot
bad flat spot between 5-6k rpm. just had the carbs cleaned. they say ir needs a jet kit to fix the dead spot. thing feels like it's gonna stall going down the road. any ideas?
Old May 19, 2007 | 06:34 PM
BlkF2's Avatar
Default RE: Flat spot
sounds like a need for a jet kit...
Old May 19, 2007 | 11:35 PM
Hlavkb's Avatar
Mine bike has developed a slight flat spot too, around 4500rpm. Not bad enough to feel like it is stalling, just a little sputter in the power/exhaust. It came to when I rode in the rain, but has continued since then. Is there an adjustment that I can make, or do I need a jet kit?
Old May 23, 2007 | 10:10 PM
ladybug600's Avatar
I had the same problem!!! i went down a tooth in the front sprocket and that helped my flat spot. however i lost my top end so i did a stage two along w/myK n N.....damn loving it now.....sweet!!
[IMG]local://upfiles/5751/00B31AAC15DF44E1BD52D849EAE28453.jpg[/IMG]
Old Jun 5, 2007 | 10:04 PM
braundy2003's Avatar
Hi i get flat spots in my bike between50+ MPH but nothing before is there anything i can do to solve it? I did go and get dyno jets and set up on a dyno and it wasnt as bad after that but it's still there. below is the results of the dynojet. Thanks in advance. Des
[IMG]local://upfiles/17529/C0237C209391462682F01E52826FFD17.jpg[/IMG]
Dazb13
Jan 16, 2013 12:20 AM
Jordan Fonte
Jun 9, 2012 08:46 PM
lloydiecbr
Sep 18, 2009 01:48 PM
radboy58
Aug 19, 2009 09:09 AM
Triggy
Mar 4, 2009 08:25 AM
