Flat spot
Old Jan 15, 2013 | 01:33 PM
Dazb13's Avatar
Default Flat spot
Evening all, the 600rr I picked up had been sat in the guys garage for 7 months. Been out a couple times on it and it rides ok but a guy at work mentioned a "flat spot" as it been sat on a rear paddock stand with all the weight on the front tyre. I assume this would be noticeable but it looks ok ! What's your thoughts ?
Old Jan 15, 2013 | 02:57 PM
Sebastionbear1's Avatar
G'Day Dazb
If the front tyre had a flat spot you *would* notice it during a ride. A regular thump, thump, thump as the wheel turned. I have bikes that sit for months on their centre stand with weight on the front wheel - not as much weight that a rear paddock stand would cause, but have never had a problem with flat spots.
Cheers, SB
Old Jan 15, 2013 | 07:12 PM
CorruptFile's Avatar
June 2013 ROTM
Make sure you check the tires for dry rot etc... Cracks in the sidewall can spell disaster!
Old Jan 15, 2013 | 07:32 PM
TahoeRider's Avatar
Yes definitely make sure the tires aren't rotted or cracking. If you can't feel a vibration or a thumping while riding the bike and the tires are in good shape I wouldn't worry about it.
The DOT number on the sidewall will tell you when the tire was manufactured.. should be a 4 digit number, the first two are the week (01-52) and the second are the year. Personally I wouldn't run on anything older than 4-5 years.
Old Jan 16, 2013 | 12:20 AM
Dazb13's Avatar
Cheers geezers, just passed my test 6 months back. Had 125,s 20 years ago but getting back into it now. All advice greatly recieved !
Jordan Fonte
Jun 9, 2012 08:46 PM
lloydiecbr
Sep 18, 2009 01:48 PM
radboy58
Aug 19, 2009 09:09 AM
Triggy
Mar 4, 2009 08:25 AM
Foght
Jun 5, 2007 10:04 PM
