fan not turning on
how close is close? it gets pretty far up before the fan kicks on, plus its not really noticable over the engine.. when it is that hot, hit the kill switch and then you can hear if it is on or not. I think there is a sensor on the radiator itself... i am not 100% on that, but is is possible that could be bad as well.
Just checked, it is called the FAN MOTOR SWITCH. Not sure how you would test it though.
If you're facing the bike looking into the headlight the switch will be on the lower right side of the radiator.
It was the fan motor switch that gave me the problem. Where do I find one to replace it? I am tempted to install a manual on/off switch(bypass the fan motor switch) since I can turn the fan on if I gound it. I think a simple push button switch (about $1.00) should do the trick. I would just mount it on the tree or the handlebars somewhere. If the replacement switch is expensive I might just do that.
I know this is an old post, but I had the same exact problem and thought it was my switch also. It actually was a bad ground to the radiator. Just take a jumper wire and go from the frame to the radiator or the base of the switch to see if the fan will come on. Hope this helps. Peace!
