F3 carbs fit a F2?
Old Oct 22, 2004 | 03:44 AM
Nipz's Avatar
Default F3 carbs fit a F2?
Does a CBR600F3 carbs bolt right on to a F2?
Thanx
Nipz
Old Oct 22, 2004 | 09:26 PM
sirlimpzalot's Avatar
Default RE: F3 carbs fit a F2?
I believe that they will bolt on, but remember the F3 carbs used the ram air system and are set up for that so if you put it on you will have to really mess with the settings or install the F3 ram air system as well as the F3 body to incorporate the system
Old Oct 26, 2004 | 01:57 AM
Nipz's Avatar
ok thank! do you know how hard it is to get the ram air in?
Old Oct 26, 2004 | 02:29 AM
cbr600f2rydah's Avatar
It would be a lot easier just to fabricate an f3 body to fit on it like sirlimpz said.....But do the f3 carbs really flow that much better for the work of swapping them.....cause if it was up to me, I would take the carbs to a machinist and have him rework the stock carbs before I did all that work.
Old Oct 26, 2004 | 03:00 PM
I know that Targa sells coplete front plastic kits for the F3 that comes pre-painted..and the guages may not fir since the F2 uses cable operated speedo and the F3 is digitally controlled..so I would just get a jet kit and work it that way...
Old Nov 13, 2004 | 09:23 PM
Nipz's Avatar
Thank for all the info. just the f3 carbs are a little bigger. But i would proble have my carbs work over to save time but that down the road.
Thanx
Nipz
Old Mar 2, 2017 | 06:58 PM
Dakota Moore's Avatar
does a f3 crab kit work on the f2 carbs?
Old Mar 3, 2017 | 12:10 PM
74demon's Avatar
Really old thread....
Feel free to start your own thread and ask all the questions you want.
Spazbite
Sep 3, 2011 10:12 AM
vettefan
Dec 2, 2006 01:14 AM
vettefan
Dec 1, 2006 10:29 PM
yellow_900_rr
Aug 10, 2006 09:59 PM
