F3 carbs fit a F2?
Does a CBR600F3 carbs bolt right on to a F2?
Thanx Nipz |
RE: F3 carbs fit a F2?
I believe that they will bolt on, but remember the F3 carbs used the ram air system and are set up for that so if you put it on you will have to really mess with the settings or install the F3 ram air system as well as the F3 body to incorporate the system
ok thank! do you know how hard it is to get the ram air in?
It would be a lot easier just to fabricate an f3 body to fit on it like sirlimpz said.....But do the f3 carbs really flow that much better for the work of swapping them.....cause if it was up to me, I would take the carbs to a machinist and have him rework the stock carbs before I did all that work.
I know that Targa sells coplete front plastic kits for the F3 that comes pre-painted..and the guages may not fir since the F2 uses cable operated speedo and the F3 is digitally controlled..so I would just get a jet kit and work it that way...
Thank for all the info. just the f3 carbs are a little bigger. But i would proble have my carbs work over to save time :) but that down the road.
Thanx Nipz |
does a f3 crab kit work on the f2 carbs?
Originally Posted by Dakota Moore
(Post 1302617)
Feel free to start your own thread and ask all the questions you want. |
