F2 tank on an F3
RE: F2 tank on an F3
Pretty sure the tanks themselves are identical. The fuel valve is the only different bit I believe. F2's have a vacuum operated petcock and F3's have an electric fuel pump. At least I'm pretty sure that is the case. If you've got the fuel pump, I'm about 80% sure it will work. I don't know anything about getting the vacuum operated pump thing to work on an F3 but if you've got the petcock from the old tank then you're golden, because they are completely identical in that regard.
Check out this thread for a little more information: https://cbrforum.com/m_497971/tm.htm
Specifically post # 5.
SACBR
06-19-2011 11:09 PM
