F2 mods and photos
Old Aug 6, 2008 | 05:52 PM
jp_greenville13's Avatar
Default RE: F2 mods and photos
check out the help section. there are some words you need to avoid using correctly. a few of these include whil.e, us/e, li.ke, k ill, and there are some more but i can't think of them. also u.se the preview button to see if you're going to lose your post
Old Aug 7, 2008 | 04:24 AM
vallip's Avatar
Well just finiched replacing the fork seals last night, now I have replaced all the fluids in the bike
On the front brake brackets then I drew those up in A.cad, the motor mount / TPS sensor bracket a well, and had them c.ut in a water j.et.
It just saves so much time, when I gout them it was just a matter of bolting them on, no need for any extra work to be don. Well except on the TPS, there I had to tap a few holes and stuff li.ke that.
Old Aug 7, 2008 | 04:28 AM
vallip's Avatar
O and one more thing I have don, I fabricated all the spacers on the bike from aluminum. The motor mount spacers and the wheel spacers that is, it saves a bit on weight but the most important thing is they look a lot bettre
Old Aug 7, 2008 | 04:51 PM
vallip's Avatar
just a small update, I uploaded a photo of the new spacer that I just fabricated to replace the speedo drive. I installed a new seal 35mm X 55mm X 7mm and the spacer is id 20mm OD 55mm length 35mm.
www.flickr.com/photos/vallip
Old Aug 22, 2009 | 08:55 PM
937brad27's Avatar
what fender kit you have and also where you get headlight
Old Aug 23, 2009 | 10:46 AM
young_gun's Avatar
Beautifull...I wish i had the knowledge to do all those mods
CJardine
May 15, 2012 07:52 PM
harry james
The Hurricane Saloon
Jul 18, 2009 03:36 PM
speedygonzalez954RR
Oct 22, 2008 07:15 PM
weekendrider
Aug 4, 2007 05:33 AM
