F2 mods and photos
Old Aug 5, 2008 | 04:35 AM
vallip's Avatar
Default F2 mods and photos
Well I thought I’d update you guys on the mods I have been doing on my bike so far.
1.Two brothers stainless steel full race exhaust
2.F3 carbs including the TPS sensor and no I did not modify the frame to fit the sensor.
3.F3 airbox including the ram air system
4.Dinojet kit
5.Cylinder head ported and milled
6.F3 radiator
7.F4i front brakes including master cylinder
8.Steel braded hoses
9.F4i rear shock
10.F4i clocks
11.900 RR speed sensor pickup
12.F4i Temp sensor , milled and re threaded to fit the original location
13.Steering damper
14.O2 sensor and display ( made that myself )
15.-1 +2 sprockets
16.K&N air filter
17. Lighter front headlight, plastic lens not the heavy stock glass one
18. F3 wire harness, relays and CDI
19.Some chroming and polishing
20.New clutch
21.New 2nd and 6th gear, shift drum, shift forks
22.New wheel bearings, front and rear
23.Other items I cannot remember right now.
Have a look at the bike at www.flickr.com/photos/vallip and tell me what you think
Old Aug 5, 2008 | 01:31 PM
Clur's Avatar
Default RE: F2 mods and photos
OMG.. i shat myself.. *DROOL* i just bought my first bike.. f2 thats in need of some work so i joined this forum in hopes to find some answers to questions i may have later on.. i have not seen many of the members rides yet.. but after seeing yours im happy with my decision on this bike.. now i just need to clean it up. thanks for the inspiration and keep it up.
Old Aug 5, 2008 | 04:19 PM
jp_greenville13's Avatar
damn that is one clean f2. drill some holes into the top of the airbox for a lil more airflow
Old Aug 5, 2008 | 06:58 PM
vallip's Avatar
Thanks guys, I have tried to keep it clean from the day I bought it new from the dealer in 92', this is a 91 model but they had one left from the year before and I got it for a bit less then the 92 bike.
Yes I did drill some holes in the stock airbox when I was drag racing it but now I have the F3 carbs and ram air so there is no need to drill this box.
I have uploaded some new photos showing how I fitted the TPS sensor, you can also see the map sensor but currently I am only using it as an experiment for the data logger I have installed.
Old Aug 6, 2008 | 09:50 AM
SilverF3's Avatar
WOW HOW MUCH LOL
Old Aug 6, 2008 | 10:16 AM
sweet. nice job man
Old Aug 6, 2008 | 02:22 PM
cowboy from hell's Avatar
u using the f3 fuel pump aswell?
Old Aug 6, 2008 | 02:33 PM
brakeswhatbrakes's Avatar
nice bike bro keep up the good work
Old Aug 6, 2008 | 03:00 PM
vallip's Avatar
What I ended up doing was connecting the breather tupe from the tank to the airbox, same pressure in the tank as in the carbs.
Old Aug 6, 2008 | 03:03 PM
vallip's Avatar
I wrote a lot more on this but I can only write one line at a time
