F2 or F3 frame?
Old Jan 15, 2009 | 05:43 PM
rray12288's Avatar
Default F2 or F3 frame?
I have an f2 with a damaged frame that needs to be swapped. My question is, can I use the frame from an F3 or do I have to stick with an F2 frame??
Old Jan 16, 2009 | 05:23 AM
vallip's Avatar
Default RE: F2 or F3 frame?
Hi there
I am not sure about all the differences between the two frams but what i know is the mounting points for the radiator are not the same and you may need to use the F3 swing arm as well, I believe F2's and F3's do not have the same diameter bolt through the swing arm.
Other than that there is not much difference.
estate4life
Nov 29, 2013 07:02 PM
captain crash
May 17, 2010 06:30 PM
1993CBR
Jan 5, 2008 09:19 PM
