F2 or F3 frame?
I have an f2 with a damaged frame that needs to be swapped. My question is, can I use the frame from an F3 or do I have to stick with an F2 frame??
RE: F2 or F3 frame?
Hi there
I am not sure about all the differences between the two frams but what i know is the mounting points for the radiator are not the same and you may need to use the F3 swing arm as well, I believe F2's and F3's do not have the same diameter bolt through the swing arm. Other than that there is not much difference. |
