F2 Choke Problems
Old Mar 17, 2007 | 09:13 PM
AlpineCBR600's Avatar
Default F2 Choke Problems
So heres my problem.. I let my bike warm up and I can ride it around with the choke on FULL but everytime I go too turn the choke off my rpm's drop and my bike shuts off.. Should I just leave the choke on all the time if so will this cause any problems?? Can anyone problem shoot this for me? I dont know what too do. I just purchased a new battery and did a tune up so i dont think that could be a issue...
Any ideas guys? Thanks!
Old Mar 18, 2007 | 01:51 AM
pbrownw's Avatar
Default RE: F2 Choke Problems
slowly let the choke off, check your idle speed, might be too low
Old Mar 18, 2007 | 02:03 AM
baja74vw's Avatar
The first thing I would do is check my idle speed. Let the bike fully warm up and let off the choke slowly. If it is about to die, use the black **** sticking through the left side plastic to increase. Get the choke completely out and adjust your idle speed to the recommended setting.
My F2 would do this. Just carb adjustments. What "tune-up" did you do?
Tim
Old Mar 18, 2007 | 06:47 PM
I Got it guys! Problem solved!! It was hte idle screw.. I adjusted it and now shes running smooth! By tune up I ment Plugs, Wires, Filter, Oil change and a new battery.
Old Mar 19, 2007 | 02:34 AM
TennesseeCBRF2's Avatar
When your bike is warmed up, what's your idle speed? It should be about 1200RPM. If it's not, you might need to do a carb adjustment.
Old Mar 19, 2007 | 03:04 PM
baja74vw's Avatar
ORIGINAL: AlpineCBR600
Right on!! When I first got my basketcase F2, this was one of the problems I had. I have since rebuild the carbs and engine, but the idle screw did take some adjusting.
Old Mar 19, 2007 | 10:00 PM
thanks for the help guys, I cant wait too get out this summer.. right now one day nice.. next cold.. what the hell lol
Imaximumcarnage
Jun 8, 2013 02:11 AM
mbrown22
Nov 23, 2010 10:37 AM
cr cbr
Nov 28, 2006 04:36 PM
playa2119
May 30, 2006 08:33 PM
insanearmer
Apr 10, 2006 02:39 AM
