F2 Carb Sync
Old Apr 13, 2011 | 02:42 PM
Seadoomanls's Avatar
Default F2 Carb Sync
Ok so my bike has a MAJOR hesitation between about 3-6k RPM...it is soooo sluggish.
So I bought my joint boosts, built a homemade manometer, and hooked it up.
However, carb 3 pulled the 2-stroke oil SUPER fast...way faster than the rest.
What is a better way to do a carb sync? Nobody in my area seems to do one for these bikes anymore.
Which way do i turn the adjustment screw? I cant even leave the bike on long enough to do an adjustment...the oil would get sucked in the carb and white smoke my garage
Thanks,
Brandon
Old Apr 13, 2011 | 03:05 PM
JesseAwesome's Avatar
Get one of these. Not fluid based.
$83.95 from holeshot performance
Old Apr 13, 2011 | 03:50 PM
damuho's Avatar
Before I did my carb sync, I inspected the throttle openings while the carbs were out for cleaning. With a flashlight shining on one end and looking through the other, I adjusted the sync screws until all openings are as uniform as I can get them. When I did my sync, I barely had to do any adjustment. I learned to do this with my older Virago V-Twin.
In your case, I'd expect the opening on carb #3 to be bigger than the others. If not, there maybe other issues - not uniform compression, vacuum leaks, etc..
As suggested above, you don't need to take out the carburetors with a sync tool.
Old Apr 14, 2011 | 03:38 PM
Is there anywhere I can buy those gauges instead of paying $83.
What are those gauges called, they just measure vacuum pressure?
Old Apr 14, 2011 | 04:09 PM
buickid's Avatar
Those gauges are on eBay
Old Apr 14, 2011 | 05:17 PM
It's $83 to buy those gauges brosef!
Old Apr 16, 2011 | 07:50 AM
drzed1980's Avatar
are you just using pipe? you need to have a football pump needle type of thing in each line to reduce the suction
Old Apr 29, 2011 | 02:05 AM
Yes...I was using just pipe...i suspect I need to put something in the line. Like a football needle you say?
What have you used and where do I get it?
Im going to give this homemade manometer one more chance.
Old Apr 29, 2011 | 12:10 PM
buickid's Avatar
If you use a heavier fluid, it won't move as fast. If the liquid is getting sucked out of the line into a carb, your sync is way off, or you have a leak in the line somewhere...
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
scottiekarate17
Jul 24, 2011 03:47 PM
dakers0010
Sep 15, 2010 09:23 PM
camaropower
Mar 31, 2009 10:23 PM
chrisf
Aug 4, 2006 11:15 AM
