Coolant Reservoir Return Hose
Can anyone give me the correct routing path for the Coolant Reservoir Return Hose? Mine was buried between carbs 3 and 4 when I removed them. When I tried to replace the carbs, the hose wouldn't allow them to go all the way in, so I figured someone goofed up before me. Routing the hose next to the thermostat doesn't seem to fit properly. It seems way too tight and stressed. Any tips or photos? Thanks
You can download the service manual from here: http://hondatech.info/downloads/Moto/
Page 5-4 and 5-5 shows where they are coming through.
(REVISED)
I just checked out mine...it is actually threaded right behind the frame above the thermostat. I tried taking pictures but I doubt they will help much since my fairings were still on...but from the access point, I can see the bottom side of the hose right behind the frame.
(REVISED - again)
Found a picture of the hose when I first removed my carbs to clean it.
(REVISED)
(REVISED - again)
nsuhtrack
Dec 8, 2011 03:11 PM
