Clutch Question
Old Nov 9, 2009 | 03:33 AM
Fearless4x4's Avatar
Official Welcome Crew Redneck
Default Clutch Question
i have search for info but havent found anything that was really helpful with my issue.
My friend did the -1/+2 sprocket change on his 08 r6 and i took it for a spin yesterday. having not riden his for quite awhile, when i got on my bike today i noticed that my cluch is extremly hard to pull in compared to his. never really thought about it before since i had nothing to compare it to. is this normal for bikes of this age. is there something that i can do to remedy it. i checked the line for any signs of a kink and whatnot and couldnt find any.
also the handle itself has a bit of play in it up and down (opposite the in/out motion of engaging it) is this an issue as well?
Thanks in advance any advice is appreciated.
-sparks-
Old Nov 9, 2009 | 04:51 AM
CBRfenatic93's Avatar
It could be his clutch springs are just easier to pull. I dont think he has a hydraulic clutch?
If its always been that way on your bike check for kinks in the cable and try lubing it a bit. If that doesnt work you could get some new springs for the clutch plate. Thatll help.
Old Nov 9, 2009 | 07:32 AM
duececivic's Avatar
it sounds like your clutch cable is starting to go with the bike being as old as it is thats probably the problem
Old Nov 9, 2009 | 10:26 AM
chuckbear's Avatar
It's not necessarily an indication of any problem, just a showing of it's age most likely. New springs are an option. I'd start by getting a cable-lubing kit and see how that treats you as Fenatic suggested.
It's an old bike and probably has the original cable on it still so some lube might go a long way.
Old Nov 9, 2009 | 02:46 PM
is there a specific type of lube i should get or can i just squirt some wd-40 down the line?
idrivea3
May 9, 2010 12:03 AM
02f4irider
Mar 6, 2009 07:50 PM
lakaiguy
Nov 8, 2008 10:54 AM
SNOWMAN
Feb 6, 2008 03:26 PM
Stray Cat
May 1, 2007 02:21 PM
