Clutch?
Old Feb 13, 2005 | 09:38 PM
Nipz's Avatar
Default Clutch?
So I got a CLUTCH KIT from DP that is complete with fibers, springs and Barnett steel plates. Is there any other part I need to replace? well besides the cover gasket, also is there any other special tools I will need to change the clutch? So far I cant get the big lock nut off. The whole clutch center seems to be moving, as well as there is a stake in it that I cant seem to get out! Please help me if you have done this before
Thank You
Nipz~
Old Feb 17, 2005 | 04:24 PM
sirlimpzalot's Avatar
Default RE: Clutch?
Did you get your clutch together yet?? And I am taking it that you recieved your clutch; right?? Hopefully it is all together now, if not try callin me 877-417-9816
Tom
Old Feb 20, 2005 | 08:46 PM
Nipz's Avatar
Default RE: Clutch?
na it not together had to order a tool. so when that come in i will be doing that.
Nipz~
Old Feb 20, 2005 | 08:53 PM
L8X's Avatar
L8X
Default RE: Clutch?
whats a clutch kit?
Old Feb 20, 2005 | 10:53 PM
Nipz's Avatar
Default RE: Clutch?
here is what i got
Barnett Kevlar Racing Clutches
When it comes to building clutches for the meanest engines in the world, nobody beats Barnett. The new K-9(TM) Kevlar clutch uses CNC-machined 6061-T6 clutch plate cores for more drive-tab contact with the clutch basket and maximum durability.
that what it says on the web page for it.
http://www.erionracing.com/productde...2&id=2&model=4
it something like that one.
Old Feb 21, 2005 | 06:33 AM
L8X's Avatar
L8X
Default RE: Clutch?
hmm interesting, thanks
Old Feb 21, 2005 | 09:10 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Clutch?
What the heck special tool would ya need to replace the clutch? Did ya order a new basket also? Steels, fibers and springs should only take 1hr max to change out. Be sure to soak the fibers in oil before installing -- some say overnight, I say til they're good and oily.
Old Feb 21, 2005 | 11:23 PM
Default RE: Clutch?
ORIGINAL: chainstretcher
I would agree, the clutch replacement doesn't need any thing special...just remove the bolts that hold the springs, take off the pressure plate and pay attention to how it came out so you can put it back in the same way with the new parts....as Chain said, soak the fibers before you install them and make sure you remove the old gasket material and install a new gasket.
Good Luck!!
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
