Checking the R/R and the stator....
Old 08-22-2007, 02:17 PM
Quick6Atl's Avatar
Default Checking the R/R and the stator....
Ok gang... I bought a multimeter to check the charging system. I have also printed out the instructions that were on here in the forum to check the battery, the R/R and the stator. It appears to me that I will have to remove the lower rifht fairing to acces the wiring to te stator. Is that correct?
Old 08-24-2007, 02:45 PM
Default RE: Checking the R/R and the stator....
yeah, remove lower fairing to access stator cover. did the multimeter indicate a bad stator?
Old 08-24-2007, 03:44 PM
Quick6Atl's Avatar
No.... nothing as of yet... mainly becuse the multimeter I bought from Advanced Auto sux! it did read ok on the Battery at idle and at rev.. right where it should be to indicate it is getting a charge.. but I went ahead and tried checking the R/R and got no reading at all. So I either did it wrong or the meter sux. i will let the pros check it at the shop.
Old 08-29-2007, 10:43 AM
Quick6Atl's Avatar
Update.... seems to be fine these days.. I will jsut chalk it all up to not strting the bike correctly becuaseI have been riding good distances and no problems. if anything I probably just need the carbs cleaned.
Dazed
07-21-2012 07:24 PM
slutty62cont
08-14-2005 01:06 PM
slutty62cont
08-14-2005 03:11 AM
Quick Reply: Checking the R/R and the stator....
