Charging Issues 91 600 F2
Old May 22, 2025 | 06:38 AM
Chris91F2's Avatar
Thank you, I will replace the hose.
When cranking the engine, the vacuum port on the cylinder seemed to blow air and not suck, is this correct?
Old May 22, 2025 | 08:13 AM
Ed Harris's Avatar
No, a venturi should always lower the pressure, not raise it.
I have had a diesel blowing back through the inlet port when the mechanic had forgotten to lock off the tappet adjuster but that should not be applicable.
Old May 27, 2025 | 05:41 AM
Chris91F2's Avatar
I pulled the vacuum hose off from the engine side and created vacuum. Fuel flowed freely into the carb.
Re-checked oil level and drained around 250ml from overfilled engine.
Bike started first try by choke and idled fine.
Starting to understand why they are referred to as females, hehe
Old May 27, 2025 | 06:20 AM
Ed Harris's Avatar
True, can be “needy” and they demand lots of TLC but given them what they want and they’ll purr for you :-)
Radox56
Jun 8, 2018 06:44 PM
thatzkid
Nov 10, 2016 10:16 AM
twhayward
Sep 17, 2010 06:47 AM
chaser28
Jun 5, 2010 02:31 PM
kkevin_g1
May 3, 2007 09:59 PM
